ABS dash light comes on then off
my ABS and Brake light would occasionally light up after driving for a little while. If I turned the motor off and then restarted, the light would go off and stay off. Now the ABS/brake indicator stays light but only after driving for a couple of minutes. It will still go off after restarting, but it will consistently come right back on after a driving for just a few seconds.
Any easy things this points to? its a 2001 3.0 112k miles Last edited by bopritchard; 05-15-2006 at 09:29 AM. |
Re: ABS dash light comes on then off
I'm not sure if I have the answer for this...but I'll try to get the ball rolling and others will join in. When the lights are not on...does your TC and ABS work? Step on the brake and try to slide the tires when the road is wet, does the anti-lock pump kick in? Same with trying to spin the wheels on a wet road. Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
What's weird is that the light seems to come on when I'm not braking (i.e. accelerating). It is for this reason I have been thinking one of the sensors is bad. I pulled all the sensors off and cleaned them, but that didn't help. The big problem is that I don't know how to read the ABS codes from the computer. I have access to an Actron CP9135 ODB II scanner and it doesn't pickup and fault codes. Does anyone know how I can get these codes? Any ideas? Chris |
Makes sense, I think the wheel sensors trigger the light when above 30mph when they sense invalid sensor data. When you turn it off it resets and then fails again when you reach the right speed.
1997 Pathfinder XE Air Lift Air Bags, Warn Hubs 2000 Windstar SEL |
Have you checked the fluid level? The ABS seems to be more sensitive to brake fluid levels than the regular brake system. Low fluid will light the ABS light.
I found a garage near me that would read the codes for the ABS a lot less than the dealer or some brake shop. Call around. If you live in MPLS area, PM me and I'll give you the name of the shop. Regards Dan
I second the vote to check the brake fluid level in the master cylinder.
The level sensor is very sensitive, and often trips the light when the level is even slightly off the full mark.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
