Old 05-15-2006, 07:41 AM
missclark missclark is offline
00 Grand Prix// Low Coolant Light
The Low Coolant light will not go off in my car.. It has plenty of antifreeze in it ..The car is not running hot or overheating ..Can anyone help me out with this..
Old 05-15-2006, 07:51 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 00 Grand Prix// Low Coolant Light
The coolant light is controlled by a level sensor located about 3 inches below the radiator filler neck on the right side (passenger) of the radiator. As long as there are no cooling system problems or air in the system it could be the cause and is a common problem. See pic below:
BTW - Also when checking coolant level check it in the radiator and not at the reservoir tank. With engine cold just remove the radiator cap and check level. It should be at the top of the filler neck.
Timeslip 08/12/06
AF Community Guidelines
Old 05-15-2006, 08:48 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Bob. The little metal pin gets mucked up with sludge and will cause a low coolant light to trip. If it's not clogged with sludge, then the sensor is most likely bad if the coolant level checks out (in the radiator) like Bob suggested.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
