Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-15-2006, 07:32 AM
richc46 richc46 is offline
Anti Freeze Change-2002 Century
Can anyone tell me if there is an antifreeze drain plug on an 2002 Buick Century. It is time for me to change the antifreeze, and I cannot locate the plug. If one is present, will you be kind enough to point out the location for me. Thanx. Rich
Old 05-15-2006, 10:27 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Anti Freeze Change-2002 Century
Yes, it is located on the driver's side of the radiator bottom. It is a plastic drain plug which is turned counterclockwise about 1/8th of a turn. You can use the end of a 1/4" drive socket wrench or handle.
Also the engine block on a 3.1L has two drain plugs but they are hard to access.
Timeslip 08/12/06
AF Community Guidelines
