Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-23-2002, 07:35 PM
OpticReflexion's Avatar
OpticReflexion OpticReflexion is offline
Send a message via ICQ to OpticReflexion
black top SR20/6speed in 94 240sx hatch?
how hard would this be ? parts, wiring, what kind of HP would it put out, any helpful links etc? im from the Honda forum so im new to this, thanks
and how much can i expect to pay for the engine + tranny etc thanks
Red Dragons
AF Nordic Crew #005
Old 07-23-2002, 10:14 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Well if you want the 6 speed tranny then I'm assuming that you want the SR20DET from the S15. The S15 SR20DET puts out 247hp.
check out http://www.srswap.com/f_faq.htm for info on swapping the SR into a 240. All models of the SR20DET drop right into the 240SX without any modifications to the engine bay. For the S15 SR20DET, expect to pay anywhere between 3500-7000 for it. The price will depend on what is all included, condition, and mileage of the engine. If you are going to order one then make sure you get one that is a complete set because you don't want to get a motor that doesn't include everything and then you have to search for parts somewhere.
Also, I think that in 1994 they only made the 240SX as the convertable version.
Old 07-23-2002, 10:31 PM
thanks a lot for your reply, i didnt know they were just convertibles in 94. so basically the s15 SR drops right in, so what is this custom stuff im hearing about. and where are some place that sell this motor, thanks alot for your help
Red Dragons
AF Nordic Crew #005
Old 07-23-2002, 11:07 PM
Yes, the S15 SR20DET will be an ALMOST drop in swap.. The custom stuff you are probably hearing about is that the driveshaft on the S13 has a different mounting location then the S14 and S15 chassis so that will need to be modified. Along with your motor set you will need the S15 driveshaft and the S15 rear differential because the speed sensor is located there. Here are some sites that you can order the SR20DET from:
www.srswap.com
www.unstable-hybrids.com
http://infinitemotorsports.net
http://www.jspecauto.com
http://www.venus-auto.com
www.streetimports.com
www.importautosalvage.com
www.tpautomotive.com
www.nippon-motors.com
http://www.neishlinmotors.com/
Hope this helps
Old 07-24-2002, 09:58 AM
thanks alot for your help man, a few more questions, lets say i change my oil, I have to import an oil filter from japan? and other parts like that? cause that kind of sucks
Red Dragons
AF Nordic Crew #005
Old 07-24-2002, 11:34 PM
Nah you won't have to import an oil filter from japan. I believe it is the Nissan Sentra that you can use the oil filter from. I will check on that and make sure it's the sentra.
Old 07-25-2002, 09:31 PM
i think im going to go with this setup, i got a quote wich is less then an ITR motor which I think is awesom thanks for the help
Red Dragons
AF Nordic Crew #005
Old 07-25-2002, 10:18 PM
Yep, no problem. Have you considered the other models of the SR20DET or are you pretty set on getting the S15 SR20DET? Just wondering because the S13 SR20DET can be had for thousads less than the S15 SR and it has just as much potential as the S15 SR. Whichever model you do decide to go with, it will be a good one. You can't go wrong with the SR
Old 07-26-2002, 10:15 AM
I'm pretty set on the s15, that 6 speed sounds mighty good right now, and like i said its about the price of an ITR motor which is great, im not sure about the maintenance issues since this motor is not available stateside, like what if something odd breaks? but right now im pretty sure im gonna go with this setup. oh and one more question, i read that most of the swaps come with a cluster is this to verify mileage or do you have to use this with your swap?
Red Dragons
AF Nordic Crew #005
Old 07-27-2002, 11:32 AM
Mike240sx's Avatar
Mike240sx Mike240sx is offline
Send a message via ICQ to Mike240sx Send a message via AIM to Mike240sx
Ive heard the s15's 6spd tranny isnt too good if u wanna drift etc, its awsome for highway driving tho. Alot of ppl in japan do a s14 5spd swap.
Old 07-29-2002, 12:39 PM
really? ill have to take that in mind
Red Dragons
AF Nordic Crew #005
