Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-15-2006, 06:56 AM
danowe danowe is offline
hard time starting
this morning i had a hard time starting it would sputer had to put it to the floor then it started right up
the check engine is on now. runs good getting 34 mpg it's a 1.9 98 satern
the check engine was on a week ago then went off untill today.
i would like to check the codes what is a cheep code tester and what do you think i should check.
Dan
Old 05-16-2006, 06:44 AM
Re: hard time starting
codes till me oc senser riplaced
now check engen still on started good runs good how do i reset
or could there be still somthing rong
Old 05-17-2006, 09:20 AM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
If you want to reset the computer, just remove the neg. battery cable for a few minutes.
Can you describe the problem a little bit more, or did you fix it already?
Also, where are you from friend?
Travis
Old 05-18-2006, 12:11 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
with obd 2 you reset it by removing the code with a scanner. others just pull the positive cable from the battery for 30 mins to reset everything.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 05-26-2006, 01:22 PM
it went away by it self
