Grinding Noise
I have a 1995 3.4 v6 automatic. when the car sitts overnight and i go to start it in the morning it doesnt want to start. It turns over like normal but it pudders out and makes a grinding noise. if I get it started and then go some where and try to start it its fires right up. only when sitting. if anyone has any idea please let me know. thanks
Re: Grinding Noise
If the grinding noise is in the rear then I would say fuel pump.
Re: Grinding Noise
its coming from the front
Re: Grinding Noise
starter gear is sticking.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: Grinding Noise
whats that mean
Re: Grinding Noise
When you trigger the starter with the key. It spins the flywheel with a gear that spins out on the shaft from the starter motor. Whats most likely happening is that gear is get stuck on the shaft in the start position and not getting drawn back down the shaft. So the flywheel teeth are grinding on the starter motor teeth.
Re: Grinding Noise
would you happen to know why it only happens when the car has sat for a while at least 12hours or more. how bad is it for that to be happening
Re: Grinding Noise
Well most metal expand when you apply heat. So when the gear is warmer it may slide on the shaft better than when its been sitting for a while and colder. As for being bad. Yes, after a while you will start causing damage to the flywheel and starter.
Re: Grinding Noise
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
Re: Grinding Noise
yep, sounds like you're gonna need a starter soon.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
