Old 05-14-2006, 07:23 PM
shadow322 shadow322 is offline
1995 cavalier clutch problem.
I went to push in the clutch and come to a stop but when I pushed it something snapped. I think a wire might have come off but Im not sure. Now when I push the clutch in it just stays at the bottom and doesn't come back up. What do you guys think?
Old 05-14-2006, 11:08 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: 1995 cavalier clutch problem.
Clutch Linkage?
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 05-14-2006, 11:14 PM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
ThE neW wHiP:
Old 05-16-2006, 05:34 PM
Its a hydrolic clutch to if that helps.
Old 05-27-2006, 06:38 AM
wcamaddox wcamaddox is offline
Its more than likely your master cylinder for the clutch. GM recommends replacing the master cylinder and the slave cylinder on thr tranny every time you replace the clutch/pressure plate/ throw out bearing. But being broke like most of us are it doesnt always happen that way.Or the linkage at the slave cylinder end could of slipped off or there could be a return spring on the clutch pedal itsself that could of snapped.
Bill
Old 05-31-2006, 12:12 PM
On thinking on this some more check you pedal it may have a spring on it that "helps" it return to the up position that may have been the snapping noise you heard.
