Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-14-2006, 04:42 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
hey guys alittle help needed
Hey guys im new to this section of af. Im normally on the dodge neon section, my moms has a gc 1999 the chweck engine light is on and when you do the key dance p 1496 comes up on the digital odometer and then says done. Now i tried to search for a list of error codes but i found nothing.
thanks
sean
Old 05-14-2006, 06:19 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: hey guys alittle help needed
I am not showing that code (P1496) in my book,
I would take it to AUTOZONE and have them scan it they could tell you what the code means.
Old 05-14-2006, 10:25 PM
GregA's Avatar
GregA GregA is offline
Originally Posted by skatendestroy
p 1496 comes up
I did a google search and found the following on at least 2 sites:
"5V Supply, Output Too Low"
What 5V supply? I have no idea!
Hope this helps.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 05-15-2006, 06:41 AM
5V supply is a wire, certain sensor use 5 volts to operate and some use 8 volts to operate apparently the 5V supply wire might be bad somewhere and grounding out and it is loosing power somewhere....
Old 05-15-2006, 06:52 PM
GregA's Avatar
I believe the P14XX codes have to do with "emission control systems" but I am not 100% sure.
Greg A.
Old 05-15-2006, 09:20 PM
JDPascal JDPascal is offline
Ya the computer supplies a 5 volt signal to the sending units and then monitors the voltage drop in the circuit caused when the sensor changes resistance.
Check the connections in the wiring harnes for that circuit first. Might not look like corosion but unplugging them and hooking them back up might fix it or you might find the bad connection is obvious.
JD
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
