Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 05-14-2006, 04:46 PM
wgrimsley wgrimsley is offline
Smile Procedure for draining coolant from 1998 Concorde
What is the proper procedure for draining the coolant from a 1998 Concorde with 3.2L engine
Old 06-05-2006, 08:40 PM
windowpane windowpane is offline
Re: Procedure for draining coolant from 1998 Concorde
From my FSM:
Start with a cold engine place a collection bucket/pan under the drain cock, lower right side of radiator, rotate it counterclockwise 180' to the full open position remove the coolant pressure bottle cap and open the bleed valve.
When ready:
Remove the cylinder block drain plugs located under each exhaust manifold.
When refilling, Use only a 50/50 mixture of the specified ethylene glycol type antifreeze/coolant and distilled water. OR whatever your owners manual says to use it should be with distilled water not tap.
IF you need/want the whole process you can join www.alldatadiy.com and get an E-version of the FSM, it has just about everything in the FSM, only a few things I just could not find but might be in there.
John
Old 06-07-2006, 11:01 AM
Smile Re: Procedure for draining coolant from 1998 Concorde
windowpane
Thank for the information
