Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-14-2006, 06:15 AM
mattd424 mattd424 is offline
please help
me my wife and kids are stranded 250 miles from home our 95 bon 175 k 3800 when i put it in park rpms jumped up n down a lil then stalled.power windows didnt work rear defroster button turned my interior lights on and off i had 12.6 volts and no fault codes it crank and cranks but wont turn over.after awhile it started dont know how drove perfect no sign of problems.now it did it agin.please help thank you
Old 05-14-2006, 06:38 AM
Re: please help
ok ive done sum searching havent checked or tried anything but could this relate to a ground problem?if so can i just run a ground from engine to battery?if im way off trck please let me knoe im just desperatly searching
Old 05-14-2006, 10:27 AM
maxwedge maxwedge is offline
A990 racer
Re: please help
When it won't start you need to check for spark as it cranks over, at the plugs, basic diagnostics, if none suspect either the crank sensor or ignition module.
Old 05-17-2006, 02:52 PM
Re: please help
it does get spark but any sensor wouldnt explain the rest of the electrical system going brazirk
Old 05-17-2006, 06:44 PM
A990 racer
Re: please help
If you have spark and fuel pressure and injector pulse it should run regardless of the other issues, there is a ground junction under the carpet l/s outer sill area, this could if corroded, account for the symptoms also.
Old 05-17-2006, 08:03 PM
luminaapv3 luminaapv3 is offline
Re: please help
I had a similar problem with my 98 caravan, ended up being my alternator! Don't know if this helps, but it could be your problem too. Take the alternator to a autozone to be checked.
Old 05-18-2006, 07:28 PM
Re: please help
ive got a tester alt tests fine.maxwedge that ground cant actually stop it from runnin can it?
Old 05-19-2006, 06:26 PM
A990 racer
Lightbulb Re: please help
I believe that is the fuel pump ground.
