Go Back   Automotive Forums Car Chat > Buick > Riviera
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-14-2006, 01:19 AM
alkemist's Avatar
alkemist alkemist is offline
How often should I change transmission filter + oil on a 100 k car?
Hello,
Because I had sometimes vibration when I shifter into reverse and 1st to 2nd gear switch was kind of rough, I just changed 7 quarts of transmission oil and filter. Inside the pan I found alot of metal dust and dirt and figured it had never been cleaned. Transmission is alot nicer now, The car has over 100,000 miles.
How ofter should I perform this transmission cleaning procedure?
Old 05-14-2006, 10:59 AM
96riviera18 96riviera18 is offline
Re: How often should I change transmission filter + oil on a 100 k car?
every 30-50k miles depending on how the fluid looks. how big were the metal pieces on the magnet?
Old 05-15-2006, 09:16 AM
alkemist's Avatar
Metal fragments were microscopic. But the amount of them was fairly high. It took about 10 bounty sheets to wipe it off before I cleaned it with brakeclean. I love the way my tranny works now. Id recommend this procedure to anyone with an old car 100%.
Old 05-16-2006, 11:34 PM
plathegame plathegame is offline
i would never change the fluid in the trans on a car w/ close to or over 100k miles unless i am certain it has been regularly done in the past.. when you drain that old fluid out all the loose clutch material goes w/ it and you are left w/ big spaces between the clutches usually resulting in slippage
06 sierra denali 6.0 max
66 grand prix 389
00 caddy escalade 5.7
95 riviera supercharged 3800
85 park avenue 3.8
86 trans am 5.0 tpi
Old 05-17-2006, 03:49 PM
he didnt flush the fluid, just replaced what was in the pan and the filter. nothing should have been dislodged since its just a pan of old fluid that was replaced wiht a pan of new fluid and a clean filter(IIRC the old trany fluid was burnt and lost most of its viscal properties thus the reason for the change)
Old 05-17-2006, 04:38 PM
alkemist's Avatar
thats exactly why I went ahead and did the fluid/filter change. thank you
Old 12-13-2006, 06:58 PM
Riviera972006 Riviera972006 is offline
i just bought a 97 riviera that has 133k miles on it should I do the same as Alkemist or take it to the dealer
Old 12-14-2006, 12:17 PM
alkemist's Avatar
Why take it to the dealer?
I say if your tranny is behaving normally and shifts nice and smooth, dont do it. If shifts between gears are almost unnoticeable and do not jolt the car than most probably the fluid is good condition and there isnt too much dirt in the system/filter.
If you do notice harder than usual shifts especially 1st to 2nd gears (like I had) changing the filter wouldnt hurt, UNLESS you flush the entire system, Flushing is not recommended and may lead to tranny failure in future.
Old 12-14-2006, 12:19 PM
alkemist's Avatar
by the way ever since that time I changes my fluid... its still in perfect condition. very clean. transmission behaves beautiful.
Old 12-14-2006, 12:48 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Riviera972006,
Please do not resurrect old threads. Any thread over 3 months old. If you have an issue or need advice the best thing to do is make a new thread/post. See forum rules at link below:
http://www.automotiveforums.com/vbul...d.php?t=635175
Thread closed.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
