Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-14-2006, 12:34 AM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
Oxygen Sensor causing major problems... i think...!!!!
its a 95 yj with a 2.5L i've been 4 wheeling a couple of times and everytime i get into water around a foot deep my jeep starts sputtering and sometimes dies on my ... i have to set there and rev it up for a while or drive or normal road to get it to run right again could this be water getting in the oxygen sensor and shorting it or something and mess the air fuel ratio up so bad that it would do that??? any ideas on what it would be if not that?
Old 05-14-2006, 12:56 AM
Ray H Ray H is offline
Re: Oxygen Sensor causing major problems... i think...!!!!
Could be but Im more inclined to think its something in the ignition. Its pretty common for the distributor cap to get wet inside. Keep a screwdriver handy and the next time it happens, pop the distributor cap off and dry it out and see if it runs ok then.
Old 05-14-2006, 06:21 PM
wilson05's Avatar
i just dont see how the distributor cap could be that likely to get wet ... i mean i dont go water fording just you know your basic mud and dirt and all that... but ok i guess i'll try that ... i just didnt think about that because i figured it was to high to get that wet
Old 05-14-2006, 08:28 PM
wilson05's Avatar
ok i did check it just now and there was mud on the inside of it but like i said and its running fine at the moment but anytime i go off roading like that it seems to act up but i guess i'll try to dry it out next time and see if that helps
Old 05-16-2006, 11:20 AM
mudcrazed mudcrazed is offline
I agree with the other poster. You might have a small crack in the distributor cap that's causing the probem. Next tiem you go wheeling bag it and tape it off with duct tape and see if that doesn't fix the problem.
Old 10-29-2006, 06:12 PM
aspiderfreak aspiderfreak is offline
if your TPS gets wet(throttle positioning sensor) it will bog.....they're cheap (20-30$) and easy to install. I got a new one and put a little silicone around the seal......never had a problem since
Old 11-27-2006, 11:19 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Try this..
Go out to the drive and hose down the O2 sensor while the engine is running. If that is the problem you will be able to see it right there.
Spray all around the under carriage to see if you happen to have a short in any wiring.
Please post the response.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
