91 thunderbird
please help got this car at auction and it has a keyless entry alarm. cant lock doors. its a 91 thunderbird 5 speed supercharged vin is 1FAPP6411MH175943. would apprecaite the help
Re: 91 thunderbird
Do you mean you can't lock them from inside with the remote or both, what about manually. If you can do it manually but the remote and the button doesn't work you probably need to replace the solenoids, but I would check them first. If it is just inside it could be the switch.
A founding member of HNF car club! Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide! ![]() Racing a Honda is like being in the special olympics even if you win your still retarded! |
Re: 91 thunderbird
i can lock and unlcok but have no remote. its a keypad on door for alarm.if i unlcok alarm goes off
Re: 91 thunderbird
The code for the keypad should be on one of the trunk hinges
Re: 91 thunderbird
i have checked there and all over vehicle and they removed it. is there any other way of getting it.
Re: 91 thunderbird
On my 90 T-bird SC, I found the code on the alarm control box. It is behind the carpet on the left side of the trunk.
If you look outboard of the left hinge you will see a hole in the carpet for the fuel pump inertial reset switch. If you pull back the carpet there you will find a box attached to the side of the car. Pull that box out and the most forward controller mounted to the box is for alarm. It should have the code marked on the outside of it. Clark |
Re: 91 thunderbird
ty it was on the the one piece in trunk.it works great now.
