Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-13-2006, 09:55 PM
zx6r zx6r is offline
95.5 Rodeo 3.2L cranks but wont start
As per title, recently many times whne I come to start the Rodeo, the engine turns over but wont fire. Whenever this happens I have notice that the "Check engine", AT, and one other warning light does not come on at start up. If I get those lights to come on, it cranks and fires..
Also since the trouble starting started happening, the rodeo has cut out totally while driving along. Again if I don't get the warning lights, after the cutout it wont start back up. But if I do get them it starts.
At first this failure to start was only now and then. Now I am lucky to get the thing to actually start, and I have resorted to disconnecting the battery completely overnight, reconnecting in the morning and so far it has started say 90% of the time I do this. ( I know disconnecting the batt sounds weird, but it works ! )
I am suspecting the ECU ? Anyone know where it is ? Does the 95.5 have an OBD-II port ( I have a OBD2 reader ) , if it does where is it ?
Any help tips , info appreciated
Old 05-14-2006, 11:34 AM
Ramblin Fever Ramblin Fever is offline
Re: 95.5 Rodeo 3.2L cranks but wont start
Have you checked for any loose ground/volt connections, i.e. specifically the battery cables?
Also, have a load test done on your alternator. Could be something as simple as losing connection.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-14-2006, 01:14 PM
Thanks for the reply, I'll check for loose connections, just in case.
But one point I didn't make clear in my posting is that usually I have to turn the iginition on and off many times, in an attempt to get "all" the warning lights to come on. If I get all the warning lights on, then it will fire.
In light of this I did take apart the steering column and see if there was something wrong with the ignition switch , but it checked out fine.
