Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-23-2002, 09:25 AM
SigTau18 SigTau18 is offline
Send a message via AIM to SigTau18
NOS on a Turbo
Hello my civic brethren,
I have a basic setup on my car right now. As of today my civic has Altezza Gen. 2 tail lights, a Greddy crome exhaust tip, a Pioneer head unit, a Kenwood 600wt amp, and a 12" DB1 Kenwood Sub. I have ordered an aem air intake, mugen grills, type R shift knob and red indiglo race pedals. In the future i plan on putting a Greddy or Garret Turbo in my car and i was wondering about NOS on top of that. Is it wise to put a high amout of NOS on an already turboed car? Should i go to a bigger turbo, or will the turbo lag increase with a bigger one? Also i am looking at other ways to increase hp. I have seen the idiots on ebay that are trying to sell the bilge pumps as superchargers and i know thats not the way to go. Please write me back and let me know about the NOS on top of the Turbo and hp gains. Thanks alot!
Mike Garber
96 Honda Civic EX AT
Generation 2 Altezza Tail Lights
Greddy Chrome Exhaust Tip
AEM Cold Air Intake
Mugen Front Grill
Si Style Lower Grill
Red Indiglo Pedals
Type R AT Shifter
Pioneer Head Unit
600 Watt Kenwood Amp
Kenwood DB1 12" Sub
One must weather the storm and find the energy that is there, fight with all one has and overcome, overcome them all. It is an uphill battle when you are near the end, but you must fight it, overcome, and be one at all costs.
-Justin Yamnitz
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis. -Jack Handy
Old 07-23-2002, 12:41 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well I guess it really depends on how much boost you plan to run. N2O is great with turbo setups for two reasons.
1. If you use it right off the line it eliminates turbo lag and spools the turbo instantly.
2. N2O has an intercoo,ling effect, so it will cool the air a little more.
If you plan to run more than 10 PSI and N2O, you are going to need some heavily forged internals to handle 10 PSI and a 100 shot of juice. I just all depends on how much boost and N2O you plan to run.
Old 07-23-2002, 01:34 PM
And another Question
Thanks alot polygon, but i have another q also. I have heard some people complaining that with an aem cold air intake, there check engine or other lights come on...are there ways around that or is there really something wrong with the car???
AEM Cold Air Intake
Mugen Front Grill
Red Indiglo Pedals
Type R AT Shifter
Pioneer Head Unit
Kenwood DB1 12" Sub
-Justin Yamnitz
Old 07-23-2002, 05:42 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
100 shot of nos on top of 10psi?!?!?!
i'd run maybe like 75 shots or something..but 100? i'm assuming you have a lot of money then
Old 07-23-2002, 05:44 PM
GSteg's Avatar
Re: And another Question
disconnect the battery from the car (negative first then positive) and leave it for about 15 minutes. that should reset the ECU. after that has been done, reconnect the battery (positive first then negative)
Old 07-23-2002, 06:50 PM
Thanks
Cool, thanks alot! I talked to an automotive shop and they didn't want to touch it because they said that they have had problems with those lights before, but now i know what to do. Thanks again!
Garber
AEM Cold Air Intake
Mugen Front Grill
Red Indiglo Pedals
Type R AT Shifter
Pioneer Head Unit
Kenwood DB1 12" Sub
-Justin Yamnitz
Old 07-23-2002, 08:15 PM
Polygon's Avatar
The Red Baron
Yeah, that is why when I run N2O it will be a 25 or 50 shot just so I can use it to sppol on the turbo on the launch.
Old 07-24-2002, 02:34 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Come on guys...If you're going to use nitrous, go big!!! Hopefully things will go right and I'll have another LT1 in the very near future to play around with...I'm going to turn it into a HUGE nitrous car...Can we sayed forged everything and a 400 shot of n2o We'll see... Anyways, as stated above, a lot of times people will use the nitrous as a way to counter turbo lag by spraying right off of the line. I personally think that it's overkill in anything but a drag-only vehicle, as you'll almost surely need slicks if you spray right off of the line, in which case you won't be driving around on them. I say look into other options to counter turbo lag.
There's no replacement for displacement...No, not even a turbo.
Old 07-24-2002, 08:48 AM
GSteg's Avatar
the only problem going big for him is that he is going to run a turbo, which the D16Y6 isn't built for, on top of that, nitrous too.
if he goes with a large turbo, then turbo lag would be virtually impossible to eliminate, bucause his B16 doen't have enough CFM and velocity to spin it. only if he had an LS1 or LS6
Old 07-24-2002, 05:15 PM
Question Using a Button?
One of my fraternity brothers has a NOS system in his car. We were BSing about it and he was showing me how it was hooked up. He has the engager for the system hooked up to his throtle. He said it was better then having a button (i.e. Fast and Furious style) because it let the car put the boost in at the right time rather then an inexperienced person using NOS. Do you guys think this was a good idea or not? Let me know.. Thanks!!
Garber
AEM Cold Air Intake
Mugen Front Grill
Red Indiglo Pedals
Type R AT Shifter
Pioneer Head Unit
Kenwood DB1 12" Sub
-Justin Yamnitz
Old 07-24-2002, 09:20 PM
GSteg's Avatar
Re: Using a Button?
Garber
yes it is true..they made the kit to operate only at wide open throtte, meaning it'll activate only if you smash the throttle. this is done to keep the car from wheelspin when it launches. also, it may not work in 5th gear if you have a manual because it protects the gear from dying. the 5th gear is always the weakest compared to the other 4. i would say use the same setup. using if off the line will create a lot of wheelspin.
Old 07-24-2002, 11:50 PM
Self's Avatar
Re: Using a Button?
Garber
Yes, this is the ONLY way to go...Need to have a WOT switch, so as GSteg said, it only activates when you have the pedal on the floor, and also it's essential you have a Window Switch, so it only operates between a specified RPM range...Say 3000 - 5000(stock LT1, varies for every vehicle). This keeps the system from spraying if you accidentally shift late and the engine hits the rev limiter...What happens is when you hit the rev limiter it cuts the fuel from going into the engine. Without a window switch the nitrous would keep spraying even though the engine is getting no fuel. I'm not going to go any further into than that, but just know that nitrous without fuel going into your engine is BAD. Also, if you want to be completely safe(a good idea...), also look into getting a FPSS(Fuel Pressure Safety Switch). This protects your vehicle by cutting the flow of nitrous if for any reason the fuel pressure drops below a specified amount...Once again, stopping nitrous from being injected into the engine without fuel.
Old 07-31-2002, 02:48 PM
cool
Hey, thanks alot guys, you've been a big help!
AEM Cold Air Intake
Mugen Front Grill
Red Indiglo Pedals
Type R AT Shifter
Pioneer Head Unit
Kenwood DB1 12" Sub
-Justin Yamnitz
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
