Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-13-2006, 10:31 AM
auto world auto world is offline
Smile tranmission help
i have 97 isuzu rodeo where do you check and fill with fuild i just got it 2 days ago thanks for any help
Old 05-13-2006, 03:34 PM
surferfletch surferfletch is offline
Re: tranmission help
Start by searching "transmission fluid" and/or "transmission" to get all the answers to your 4L30-E questions. Here's the quick summary:
Drain and fill plugs are both on the tranny pan, with the fill plug toward the rear and higher on the pan.
You can drain about 4 qts. from the approximately 9 qt. system. You refill with the engine idling in neutral. You should run it through the gears a couple of times as you top it off. You'll need a cheap hand pump to get the fluid up in there. Fluid exchange is an option. I drain and refill a couple times every 15K and I drop the pan and change the filter and gasket every 30 K. 155K and the tranny works great!
Good luck!
