Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 05-13-2006, 04:07 AM
krazyken2 krazyken2 is offline
Unhappy Engine cutting out 1990 3.8L
My engine cuts out for a split second while driving, then resumes as normal??? I had the codes checked, and the only thing that showed was my O2 sensor was falty, so I replaced it, reset the computer, and am still having this problem? Sometimes this happens after taking my foot off the gas pedal and applying the brakes, and then stalls?? Heeeeellllllllppppppp!!!! This car is driving me mad!?
Ken
Old 05-13-2006, 06:04 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Engine cutting out 1990 3.8L
Could be a vacuum leak or a bad ICM/Coil setup. None of those systems throw codes. Replace the little rubber pieces and then if that doesn't work then pull the ICM/Coils off (3 11mm nuts, 1 7mm on electrical connector...just mark your plug wires so you get them back on right).
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 05-14-2006, 03:51 AM
Thanks for the feedback!! I was over at Autozone to look for ignition repair info, and can only find distributor type ignition info?? I don't have a distributor like that one!! Mine is a square box??!!!
http://www.autozone.com/servlet/UiBr...3d800b099b.jsp
krazyken
Old 05-14-2006, 06:02 PM
Alibi's Avatar
Some 98's came out w/ a 307 (i believe) instead of a 3800. The 307 had a distributor while the 3800 had a coil/ICM assembly. Assuming you have the latter, then you may do well to search under olds 88 in autozone instead of 98, if you're having issues with parts compatibility.
-Eric
Old 05-16-2006, 09:49 AM
danbrwn danbrwn is offline
If you want to check your ignition module (the square box), take it off and take it to Autozone. I just had one go bad. I found out later that Autozone has a tester. I don't know how good it is. The Igntion module is held on with three nuts underneath. Dan
Old 05-16-2006, 07:42 PM
Alibi's Avatar
When/If you have autozone test it, ask that they test it several times. Quite often, the ICM will not fail untill after it has heated up and would require several tests to get it to operating temperatures...or if you have sticky goo coming out of it then don't bother...just replace both the coils and ICM at once with NEW parts (or obviously new from junkyard, but risky).
-Eric
Old 05-17-2006, 03:57 AM
Are the coils and ICM parts inside the ignition box?? Would it not be better to just replace the whole box?? Is there any special timing ajustment needed when changing the ignition???
Thanks
Ken
Old 05-17-2006, 07:51 AM
Thanks
Ken
The coils are attached to the ignition module with screws. At least in my case a 1991 98 reg elite. I don't know if you have to remove them for testing although I doubt it. No timing is necessary, thats what the combination of crank sensor, cam sensor, ignition module and power control module do.
Old 05-18-2006, 12:46 AM
Alibi's Avatar
http://www.thejmfc.com/autos/delcoignition.html
This is what your ICM/coil pack assembly should like like. On a 1990, you should have the Delco setup with the coils as one unit. The part with the electrical connector is your ICM (ignition control module).
-Eric
Old 05-18-2006, 12:48 AM
Alibi's Avatar
One more thing, when it "cuts out for just a moment" does the engine kinda chug, around 50-60mph? Then acts fine after you give it some gas to beyond 60?
That would definately be either the coils or icm or both.
-Eric
