Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-12-2006, 11:40 PM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
seconday air injection pump
This is leaking on a 02 jetta 1.8t on start up when the engine is cold. Is that bad? what exactly does this do? i know it injects intake air into the exhaust only on cold starts and then the valve will shut after the engine is warm to have better emmissions. the pressure clamps on the pump are loose and it leaks. what happens if i just leave it?
Old 05-20-2006, 03:47 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: seconday air injection pump
water into engine from pump that accumulates water when car is not run. Also will cause combi-valve to go bad.
Pumps are about 3-400.00
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
