Old 05-12-2006, 11:01 PM
hcivic hcivic is offline
pops out of 5 gear
I was driving the other day in5 gear and it felt lke it popped out but it didn,t . It felt like it was in neutral. A couple of days later lost all gears. Changed clutch and bought used tranny. driving home after done installing clutch and tranny it started to loose 5 gear again .
the only thing done before is changed halfshaft on drivers side please hel;p
Old 05-13-2006, 01:49 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: pops out of 5 gear
If you already replaced your clutch, I say check your axles, they might be popping out halfway from your tranny input.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 05-13-2006, 06:53 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 05-13-2006, 09:10 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
My drivers axle was halfway out and that damn thing would shudder like a mofo while decelerating in gear..at first, later on it startedto do it while just driving, pissed me off, took a look and it had no ring to hold it in!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-13-2006, 09:11 PM
on drivers side should you see any of axelshaft that goes into transaxel? or does the inner cv joint go right up against tranny?
Old 05-13-2006, 09:28 PM
FrodoGT's Avatar
On the drivers side the shaft goes into an intermediate shaft, or an extension if you will. That runs into the transmission, th passenger side goes straight into the diff.
Current project:
Rio Red 91 hatch.
Old 05-13-2006, 11:50 PM
Wait im pretty sure a stock d-series tranny in a 4th gen doesnt have an intermediate shaft. These cars have a longer drivers side axle and do not use intermediate shafts. So you technically should not see any of the axle input hanging out of the tranny. The cv joint area should be pressed up snug at tight against the differential housing.
Old 05-14-2006, 09:03 AM
Hybrid1990crx's Avatar
^^^^^ you are correct. only b series have intermediate shafts.
Old 05-14-2006, 11:26 AM
FrodoGT's Avatar
Ah, sorry..never had a d-series..my bad.
Current project:
Rio Red 91 hatch.
Old 05-14-2006, 11:49 AM
i thought the zc tranny had one (an intermediate shaft)????
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 05-14-2006, 12:13 PM
yeah i think it does.
Old 05-14-2006, 04:18 PM
Hmm so if the zc tranny's got an intermediate shaft, do d-series EG's come with them too, what about EK's, do only 4th gen d-series trannys not have intermediate shafts? I know all b-series tranny's come with them.
Old 05-14-2006, 06:18 PM
hey guys you were right the drivers side axel wasn't in all the way . It does fit tight against tranny. Thanks for the help ! your help saves me and others lots of money.
Old 05-14-2006, 07:49 PM
FrodoGT's Avatar
No kidding, that would be at least $50 just for them to tell you the damn thing was out.
Current project:
Rio Red 91 hatch.
