Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-23-2002, 12:35 AM
CapedCrayola CapedCrayola is offline
Send a message via AIM to CapedCrayola
e36 engine in an e30 325i
I have read in countless articles that you can put an e36 m3 engine into an e30 325i. however, my main concern is that there is not enough room for air conditioner in there. I live in Texas and it gets insanely hot out here during the summer. So it's basically a necessity. Is there anyway that I can fit that m3 engine in there and still have air conditioning? Also, I have heard you can put a chevy small block engine (LS1 engine) in there but it's kind of a myth I think because I can't find any mounting kits. But anywho. Thanks for reading
Old 07-23-2002, 05:21 AM
Rossco Rossco is offline
Re; E30 with E36 engine
I suggest you check out this site - http://www.zionsvilleautosport.com/
They have a CD-rom with everything you need to know on fitting an E36 engine into a E30.
They call it 'project Orca', and fitting AirCon is listed on the CD-rom.
Hope this helps
Regards
Rossco
1996 E36 320i
Old 07-26-2002, 01:57 PM
WilberM3 WilberM3 is offline
if you dont personally want to do the swap with that Zionsville CD info, www.TurnerMotorsport.com does that swap often, but theyre located in MA.
i believe www.Kormanfastbmw.com also does it and they are somewhat closer to you.
i would say theres enough room in there for a cheby small block itself, but the exhaust may pose some routing problems as could the transmission itself. the e36 M3's tranny pretty much fits right up there, but i dont know if a T56 attatched to an LS1 will, and if it does, theres no garuantee the shifter linkages will line up with the shifthole coming through the center console.
as far as actually mounting the LS1 i beleive you'd probably have to fabricate your own motor mounts.
simply put, with enough $$$ anything is possible.
Old 07-31-2002, 01:05 PM
klawria klawria is offline
go to http://www.maxbimmer.com/ and get in touch with a guy who goes by the name of empowerd. He's got the sickest e30 with a 99 m3 engine. He should be able to tell you anything you need to know
Old 08-20-2002, 11:34 PM
evo2885's Avatar
evo2885 evo2885 is offline
Send a message via AIM to evo2885
e 36 in an e30 325i
Hi...
Since you live in Texas contact www.bmpd.com. They're located in Tyler, Texas. They've done that exact engine swap for their company racing car and they used the body of an 1984 318i.
If you want info just contact them and I think i'm gonna do the exact same engine swap. Because my 1985 318i engine is just too weak to produce the horsepower I need.
PEACE!!!:smoker2: :grey: :sun: :bandit:
