Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-23-2002, 12:03 AM
Psyrage Psyrage is offline
Send a message via ICQ to Psyrage
Question about Air Filers and Intakes..
if i replace my stock 93 filter with a k&n filter would it actually add mroe power?
will i feel it?
i never went for a 0-100 test..but is that true that 93 max with 190HP does it in 11 secs? (auto)?
Old 07-23-2002, 12:07 AM
x-fangs x-fangs is offline
You should notice a slight difference. I use my intake for acoustic purposes only.
Old 07-24-2002, 08:01 AM
NJMAXSELTD NJMAXSELTD is offline
Re: Question about Air Filers and Intakes..
93 Max doesn't have 190hp. 95 - 99 has the VQ motor with 190hp. That car, stock, auto does 1/4 in 16 seconds.
11 second cars are extreme cars, not everyday drivers usually. A Maxima will need roughly 300hp to get near 11 seconds.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 07-24-2002, 05:33 PM
jayendo jayendo is offline
Send a message via AIM to jayendo
"intake for acoustic purposes only." damn then i guess you allso drilled holes in your muffler too right?
-J
Old 07-25-2002, 12:13 AM
redrum85 redrum85 is offline
Re: Re: Question about Air Filers and Intakes..
Actually the 3rd generation (a portion) did include a 190hp engine. In 1992 Nissan introduced a new engine(The VE) that were put into the SE models. The GXE models had a 160hp engine, while the SE enjoyed the beefier engine. I also belive that the engine did the 0-60 in 7.1 sec(5sp). The VQ was finally introduced to the 4rth gen maximas in 95. I should now this because i used to own a 92 Maxima SE, and i knew my car inside out....please do some research next time.
Carpe Diem...It is not only necessary, it is essential!
Old 07-25-2002, 01:25 PM
D-sta D-sta is offline
Send a message via AIM to D-sta
yeah the 3rd gen has 190 hp. I have it enough proof for me NJMAX :finger:
1992 Maxima SE 5-Speed VE Power.
MODS:Stillen HI-FLOW Intake, Tokico Blue Shocks, Eibach Pro-Kit Springs, Stillen Brake Pads, Brembo Rotors, Clear Corners, Suspension Techniques Sway Bar Kit, 2002-2003 Front FSTB, ASP UDP, Warpspeed Performance SS Y-Pipe, Carsound Cat, Greddy SP Exhaust System, SPW Industries HID PLUS 7500K Kit, 2001 Anniversary Edition Shift Knob, Stillen Tie-Down Battery Bar.
