Old 07-22-2002, 11:08 PM
coonass420 coonass420 is offline
Send a message via AIM to coonass420
b16a1 into 88-91 CRX Si Swap
I just want any information that anybody has on the swap. Any sites that have guides or anybody that has done them before. Any hints or problems i will run into. Thanx for any helps that comes my way.
Old 07-27-2002, 11:55 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
ok well first you need the motor, trans and ecu so buy it as a package. You may want to get the gearbox equipt with the LSD (limited Slip Differential) as it will increase acceleration an corner steering. What you will need are some items to make the motor fit and bolt up. I would recommend a Hasport motormount kit with matching shift linkage. You will need axles from a 90 integra and need to either get new throttle and clutch cables or modify your existing ones to work. You will need to make a dent in the frame rail below the shock tower to clear the alternator pulley. get the motor dropped in then you will need to do some wiring for the vtec. Get 4 insulated conductor wire. You will then need to wire these up to: Vtec Solenoid, Vtec Oil pressure, secondary o2 sensor and knock sensor. anything else I forget...... Start it up! Good luck if you go forth with the swap!
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
