Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-12-2006, 12:33 PM
wizard99 wizard99 is offline
92 century
my car was acting like the altinator was bad ......dim light and all that.
i had it tested and its ok so i replaced the battery. the car seem to be running ok (have not drove it at night yet) but the battery light is still staying on.
Old 05-12-2006, 04:38 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 92 century
Check the terminals to the battery and the one on the back of the alternator. If the alternator connection is bad the light will stay on. Also if the terminals or the connections are corroded then the same thing will happen. If you check them and find they are corroded clean them or replace them and the problem should go away.
Old 05-13-2006, 09:27 AM
Re: 92 century
Checked them too still have the problem.
Old 05-13-2006, 10:30 AM
Pontiac Guy
Re: 92 century
Have the alternator checked again. Also check to make sure the belt is not slipping. They don't have to squeal to slip enough to prevent proper charging of the battery by the alternator. Obviously there is a problem somewhere.
Old 05-13-2006, 05:33 PM
Re: 92 century
I guess i will break down and take it to shop. Its 1 belt for all and it seems fine.......i will post after i take it to the shop. Thanks for all the help.
