Thermostat gasket wont frekin seal!!!!!
Well Ive attempted to seal the frekin themostat gasket twice and with no luck, any advice/ technique?
And yes I use sealant.......
91 RS Camaro V8 305 TBI cold/ram 14"/3" open element K/N filter 3.73's B&M Megashifter 180 thermostat Flowtech TERMINATOR Exhaust 3" exhaust cutout Silvania Silverstar Headlights Ronal R15 Firehawk Wheels Hankook Ventus Sport (front) Sumitomo HTR+ (rear) 275/40ZR 17 all around... _____________________________ |
Re: Thermostat gasket wont frekin seal!!!!!
Make sure the surface is clean, if it has the old gasket still stuck on scrape it off or sandpaper works good too. And then RTV the shyt outta the thing. (but let it set a few minutes before you bolt it on)
![]() -2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*- |
thanks...its a pain in the buttox...
Make sure the water neck isn't pitted on the surface face causing a seeping issue form electrolisis (worn out coolant actully passing electric current through it)
A vast majority of the times I don't use RTV and have no leaks. |
rtv, alot, and let it dry before starting it and stuff. i use the copper rtv, works good
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
i dont use any, just make sure you surfaces are nice and smooth, the gasket is enough for me
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
i got an o-ring with mine.
