Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-12-2006, 07:12 AM
Tony022 Tony022 is offline
Brake Fluid Light
Brake fluid light came on, along with the " bong, bong, bong" that I couldn't turn off. Checked fluid and it needed some. Added DOT3 fluid.
Light stays on with "boing, boing , boing"
Never felt any change in brake pedal pressure or difference in brakes.
How can I reset the light and "boing boing boing. LOL. it's driving me crazy
WHat could cause it to stay on?
thanks..
tony
Old 05-12-2006, 10:54 PM
parts68 parts68 is offline
Re: Brake Fluid Light
Is it the red brake light or amber ABS
Old 05-13-2006, 04:24 AM
It's the "red brake fluid" light.
Old 05-13-2006, 07:44 AM
that indicator is for "hard" failure of brake system.
Shouldnt really be driven until its fixed.
This is why you get an annoying chime.
You may have air trapped in the ABS unit,due to running low on fluid.
next question is why did it run low?
Unless you have a leak it shouldnt run low.
Fix the leak and flush your entire brake system with good LMA
DOT 3 fluid.
Old 05-15-2006, 02:44 PM
Rezarecter Rezarecter is offline
Tony, I had the same problem with my 1995. The tank gets so gummed up and clogged that becomes inaccurate. I left my level indicator disconnected, then I got a new master cylinder with new reservoir, and i hooked it back up, and it worked fine.
either disconnect the sensor, get a new master cylinder, or have your brake system flushed.
Old 05-17-2006, 05:38 PM
The light and "boing, boing" went off the next day.
Anyhow, while putting new wires/plugs on I did notice a small drip under the master cylinder. Hmm , that's where the fluid went. I will keep an eye on it.
What's the procedure for replacing a master cylinder.. Is it involved..
