Old 05-12-2006, 06:26 AM
Jamesr_uk Jamesr_uk is offline
Headunit Problems
Hi,
I took out my standard Peugeot Head unit and replaced it with a aftermarket JVC headunit with a JVC 12 Disc cd changer.
The problem i'm having is that when i select the cd player it just turns off and on repeatedly, the radio works fine its just the cd side...
any ideas??
Thanks in advance..
James
Old 05-12-2006, 06:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Headunit Problems
do you have an amp connected to the CD player ? If so, you have probably used the auto antenna wire instead of the remote to turn the amp on.
Old 05-13-2006, 06:39 AM
Nah I have no amp attached, just a cd changer....
Old 05-13-2006, 08:51 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
is your changer switching on and off randomly, or just steadily on/off/on/off/on/off/on/off?
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 05-14-2006, 11:10 AM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
it's still possible the cd's pwr sply is being fed from your HU's pwr ant. lead
SELLING THE HONDA...
Old 05-14-2006, 12:37 PM
well what ever it was its sorted now, n I have no idea how I solved it lol...I just fitted it again and for some reason it worked, n has been working fine for a couple of days now so I think its fine..
Which brings me onto my next problem,,,,getting a Amp power lead to the battery, is there a common route I can take that wont require drilling?
And lastly does anyone now what size the speakers are in front and rear of a 206?
Thanks ver much for your help this far..
James
Old 05-14-2006, 12:55 PM
NAVY IC's Avatar
under your hood on your firewall, there should be a couple of rubber plugs that you can replace with grommets the size of your cables
