Old 05-12-2006, 01:40 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Bought 3.3bar map, 150psi Alcho injection
We'll. Ever sence I bought Dsmlink I've realised how Important Tuning is. You never really begin to understand it untill your get burried 3 feet deep in what you thougt was a pretty decent setup, only to realise you're shit was never runing very well, you have a boost leak, you have horrable LTFT's, your g/rev are fucked, and your timing is being pulled down to 7-8 (on a good day) at 5500+RPM while your CEL flashes in your eyes; all the time thinking to yourself; "WTF is going on?"
Well, I got fed up with it. I'm injecting H20 into my combustion chamber. After I figure out how to get my Timing up without H20, I'll be pretty happy!
The3.3bar map will actually let me read some accurate boost. I'm getting sick of looking at 14 psi on my logs but seeing 19psi on my gauge..
Old 05-12-2006, 07:12 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Bought 3.3bar map, 150psi Alcho injection
I was thinking o doing h2o injection too, i'm getting 9:1 pistons so i'll definetely need it when i turn the boost up. Let me know where you get it from. I know a place called cooling mist makes diy parts but it would cost almost the same as a kit.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-12-2006, 09:00 AM
I allready bought it; And did happen to buy the Coolingmist 150psi kit.
Old 05-12-2006, 11:57 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
After running the alcy for a few thousand miles, take the head off and look at the tops of the pistons, you wont believe how new they look.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-12-2006, 03:52 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Sweetness scottsee. Eventually I would like to do that but I have a shit ton more to do before. Good luck with it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-12-2006, 09:31 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
nice, i've been looking into some sort of injection to help my knock issues as well? did you adjust your airflow values as shown in the dsmlink manual?
now - 2000 civic
soon - 2002 is300
Old 05-12-2006, 10:52 PM
I don't have to. I'm on my stock 2g MAF.
Old 05-13-2006, 10:24 PM
I meant did you adjust the LFTF values as the dsmlink manual says to? Both trims pretty close to 0? That would explain why your airflow measuring is off.
now - 2000 civic
soon - 2002 is300
Old 05-14-2006, 01:46 AM
LTFTlow was at 0% and LTFTmid at 6.8% with my stock 450cc, 2g maf, with working PCV and valve cover routed back into the intake. The g/rev at idel is about .23g/rev. My LTFT's indicate my "Dead Time" needs to be lowerd. But Dsmlink can't set dead time lower then 0. So I'm stuck... Thats what sparked me to get a new fuel system. Dave though it was becasue my rewired 2g fuel pump was over runing my stock fpr. Even though I beleve its somthing else, whos to argue with pobably one of the most knolegeable DSM guru's in the world.
Old 05-14-2006, 10:19 AM
kjewer1 kjewer1 is offline
AF - Advisor
I certainly wouldn't argue with him
That MAP sensor will make life much easier. I'm running the 3.3 bar GM deisel sensor. Once you realize the power/convenience of being able to compare calculate pressure with measure pressure and calculated AFR with measured AFR there is no going back!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-14-2006, 11:16 AM
I thought DSMLink could run negative dead times? Mine are really high, so I've never had to deal with it, but I remember reading about some guys that needed it.
now - 2000 civic
soon - 2002 is300
Old 05-14-2006, 11:28 AM
If it can I sure doesn't work for me. I tryed putting just about every divisible number of 15 in the UN dead time box. It doesn't accept the - attribute, like -15. It defaults back to 0.
MR. Jewer, I'm looking forward to it. Especially the part where I'm picking up my first wideband Thursday. Calculating AFR with a water/alch injection is just to much for me to bother with without one.
Old 05-16-2006, 06:13 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i dont see any reason to use neg dead times. dead time grows as injector size grows. it would be idiotic to run a injector smaller than 450cc.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 05-16-2006, 10:06 PM
97_3clipse's Avatar
i also just got my PLX wideband, im just curious on what wideband everyone else is running? and how do you like it?
Old 05-16-2006, 11:58 PM
Thats the one I just got. M-300. We'll see how it works when it gets here.
