Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-12-2006, 01:39 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Unhappy stumbling engine
Only during moderate and excessive acceleration, my gst engine stumbles quite harshly. It sounds like it is just misfiring badly. I can distintly hear a popping sound, like a spark from the wires. I have done nearly everything the repair manual suggests: Fouled spark plugs, fuel injection system component faulty, fuel filter clogged, ignition system malfunctioning, and vacuum leak check. I swapped the plugs, wires, coils, and injectors with the gsx I have, as well as replaced the fuel filter with a new one. The gsx runs just fine with them. I do not have a gauge to test the vacuum lines though. Would they be a likely cause of this problem? What other factors could contribute to the popping noise?
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 05-12-2006, 07:22 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: stumbling engine
It could have a boost leak causing it to backfire and that could be the popping sound you're hearing.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-12-2006, 11:03 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
What plugs did you put in and what did you gap them at...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-12-2006, 11:56 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
boost leak. Do a test
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-13-2006, 09:10 AM
I had a friend of mine drive it around last night. He says he can hear an echo on some buildings of what sounds like a tiny exhaust leak. My car has a 3" exhaust so it didnt cross my mind that it was a little louder. He suggested I should do a compression test and fuel pressure test, just to make sure those are not contributing factors.
72 Beetle - trashed
92 Talon - sold
Old 05-13-2006, 01:08 PM
blk_srt's Avatar
while you are doing those do a boost leak test, actually do that first because I can almost promise you its a boost leak.
Mods:
Old 05-13-2006, 11:04 PM
ez1286's Avatar
A boost leak test is the easiest of those three the only probem is you need a compressor and not everyone has one
Old 05-14-2006, 12:04 AM
blk_srt's Avatar
You can do it at a gas station or with a bike pump
Mods:
Old 05-20-2006, 03:51 PM
i cant seem to find any instructions on how to do a boost leak test. I cant find any cracks or torn lines anywhere. It seems to be steadily getting worse on a daily basis.
72 Beetle - trashed
92 Talon - sold
Old 05-20-2006, 06:36 PM
blk_srt's Avatar
www.vfaq.com
Mods:
