hi my name is eric and i own a 85 fiero gt 2.8 auto the headlights do not go up but the relays click and i have power at each moter, both gone bad??
And gas gage dont work, it always says full, and the tack, when not running says 0 but when started it says 1 all the time even when i hit the gas, oil preser gage doent work,the car starts fine with new fuel pump but when i just touch the gas the engine rpms jump way up and stay up, i am puting a new throttle body on sinse both sensers where broke and snaped itto the throttle body , and to top it all off the car has no brakes becuse all 4 calipers are froze up and i havent got new ones yet. help please eric
Re: just started after 7 years lots of problems
I hope you have mechanical skills or a deep pocket.
Headlights www.rodneydickman.com sells rebuild kits for Fieros. After sitting for years, there probably is lots of corrosion with the various connectors into the dash. Usually with no oil pressure, the car won't start, but when the sender fails the gauge will read real high, so my thoughts are bad connectors. You may want to pull back the trunk carpet along the sides to check for hidden rust on the rear frame rails. If there is lots of rust there the car is not worth fixing, but becomes a parts car. High idle rpms usually indicates a vacuum leak, bad sensors and or cracked egr tube. Needless to say, complete brake rebuild. Invest in a Haynes Manual. |
