Old 05-11-2006, 06:41 PM
rental blazer rental blazer is offline
Angry door rattle after repair
i had the pins replaced on both doors and now the rattle is worst then ever and if my arm is on the drivers door i can feel the rattle how the hell am i supposed to fix this ??blow my ears out?
Old 05-11-2006, 09:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: door rattle after repair
the door pins being fixed will have the other components vibrating now that the pins won't be.
It is easy to remove the panel and check inside. Might be just a screw that needs tightening.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-11-2006, 10:05 PM
it could be...but i have a feeling its much bigger then a screw...its horrably loud
Old 05-12-2006, 05:27 AM
muddog321 muddog321 is offline
AF -Advisor
Take it back and complain. When they took the door off it is now probably misaligned and the gaskets are not sealing - easily fixed by a few correct treaks on door - or as stated above they forgot to tighten something or dropped something in the door. Is the seal for the wire harness fully in the grove (between door and frame) cause that will allow lots of air into the door and noise. Seen them forget that one before.
Old 05-12-2006, 07:07 AM
billibong's Avatar
billibong billibong is offline
This may sound like a stupid question...But --
When they replaced the pins did they replace the bushings??
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
