Old 05-11-2006, 05:28 PM
outwheelin outwheelin is offline
Question What are these engine codes?
I finally got my check engine light codes read by autozone. I have two codes. They are code 171 and code 174. Do any of you know what is causing these 2 codes, and what I need to fix, so the stupid light will stop coming on?
Old 05-11-2006, 06:59 PM
frostie frostie is offline
Re: What are these engine codes?
You can do a search on this forum for p0171 and p0174. Basically, these codes indicate a lean condition, probably due to a vacuum leak. Most of us are finding that this requires the "isolator bolt fix".
Old 05-11-2006, 07:40 PM
wiswind wiswind is offline
Isolator bolt fix is for 1999 and newer windstars.
You will find great information at this link....
http://leckemby.net/windstar/windstar01.html
For 1998 and older, it is still almost always caused by a vaccum leak.
These engines use a different upper intake manifold, and does not have the issues with the isolator bolts and coming apart.
Look for a loose or damaged vaccum line.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-17-2006, 06:53 PM
Thank you for the info.
