Old 05-11-2006, 03:39 PM
media media is offline
AC vacuum problem on a
1998 Astro VAn AWD Airconditioning works fine The AC only goes to the defroster, I would like a map of the vacuum hoses where they come from and where they go.
Does anyone have a simple diagram that describes. The vacuum of the AC system
Thanks
Media
Old 05-11-2006, 06:02 PM
Blue Bowtie's Avatar
Registered Offender
Re: AC vacuum problem on a
The source is at the left side of the intake manifold. There is also a vacuum reservoir mounted to the right subframe just below the A/C evaporator core case. The reservoir is plastic, and doesn't last forever.
Old 05-12-2006, 07:15 AM
brcidd's Avatar
brcidd brcidd is offline
Look in front center of intake manifold- for black plastic vacuum hose- most likely it is brittle and broke in two- have seen several do this- probably have to remove air filter box to see it though- to repair- cut out all the brittle section and use a soft rubber hose to slip over both ends- works every time......
Old 05-22-2006, 10:19 AM
Thanks to both
I will check it all out.
I am sure I have to remove abunch of garbage to get to it all.
I Need smaller hands.
Old 05-31-2006, 10:54 AM
bluelogic bluelogic is offline
The one that is probably broken is the same one I had to fix. You need to take off the engine cover and the vaccum hose is right next to the PCV value. It goes across the engine and it is black. The line is totaly not shielded from the engine and mine turned to dust when I moved it.
Hope that helps
Bluelogic
