Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 05-11-2006, 01:56 PM
lightorch lightorch is offline
Send a message via AIM to lightorch Send a message via Yahoo to lightorch
Where is the Ignition Module located
Where is the Ignition Module located on my:
1995 VIII - 4.6 liter - dual coil packs with no distributor.
Thanks Bruce
Old 08-06-2006, 09:11 PM
Marked Marked is offline
Re: Where is the Ignition Module located
All Marks are 4.6L. No need to specify engine size.
They also all came with coil packs or coil on plugs (2nd gen)
Follow the wires going into the coilback, and find the ign. module. I don't remember if the 1st gen marks had an ign. module or if the packs are controlled straight by the pcm.
Old 08-16-2006, 03:37 PM
BlackiceLSC BlackiceLSC is offline
the EDIS module is located under the plastic piece that sits atop the LEFT FRONT strut. remove the two mock-screw tabs, and pull up. it is marked EDIS.
and all 93-96 Mark VIII's used coil packs with wires.
97-98 used C.O.P.(coil on plug)
