Old 05-11-2006, 01:46 PM
missclark missclark is offline
00 Pontiac Grand prix// brake light issue
I have a 2000 Pontiac Grand Prix// middle brake light is working the other brake lights are not fuses are ok as well as the bulbs..thought it was the brake light switch but was told that if the middle light works then that is not the problem.. PLEASE HELP.. SORRY ABOUT DUPLICATE MESSAGES EARLIER//IT WAS NOT INTENTIONAL
Old 05-11-2006, 04:25 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: brake light problem//
Welcome to AF!
The brake lights all work on the same circuit. Check the lights for bad sockets and bulbs. You may have to remove the lights to check for corrosion as they will sometimes lose contact and not work. Also get a volt meter and check to see if there is any voltage at the lamps. A bad ground wire can also cause issues with lights. Hope this helps.
Old 05-12-2006, 01:11 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree with Lynn. You need to check the 12v at the lamp sockets and also the ground. If present then back track. In a worse case scenario you may have bad contacts in the hazard/warning and multifunction switch at the steering column. The 12v for the brake lamps just happens to go through those components. For some reason the high mounted brake light does not.
Timeslip 08/12/06
AF Community Guidelines
Old 05-12-2006, 05:39 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
It's most likely the multifunction/turnsignal switch assembly since your third brakelight works.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
