Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 05-10-2006, 10:53 PM
notaricajustfasta's Avatar
notaricajustfasta notaricajustfasta is offline
Send a message via AIM to notaricajustfasta
motor mounts
what do motor mounts do? do they just stiffen the engine in place so when you rev it, it doesnt twist? does that help you in any way performance wise? are they worth the money? thanks.
Old 05-13-2006, 03:26 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: motor mounts
they are one of the most useful and cheapest mods you can do. Besides it makes your car feel like a freakin race car and get ready from some serious vibrations and ratteling inside your car... lol. I love em!!
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 05-13-2006, 04:07 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Re: motor mounts
I also have them, they give you more torque. If you shift through different gears and watch your engine, it moves back and forth ALOT. With the upgraded polyurethane mounts when you do this and watch your engine, it doesnt go anywhere. The mounts transfer the energy/power your losing when the motor moves straight to the transmission and lets it shift faster/stronger. So you're not losing anything.
Old 05-13-2006, 06:56 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: motor mounts
how hard are they to install?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 05-13-2006, 07:36 PM
Lances133's Avatar
Re: motor mounts
The top mount insert is relatively easy, just gotta un-do the top cover thing over the mount and you can use Wd40 or some kind of lube and just slllide it in. The bottom one can be difficult if the motor moves when you remove the old one. You definitely want to use a lift or something close to it. The hardest part is lining up the bolt holes when installing the new one.
Old 05-13-2006, 11:11 PM
szym0n szym0n is offline
Re: motor mounts
thanks ill check them out sometime
Old 05-14-2006, 12:09 PM
Lifted GMT-360!
Re: motor mounts
I've installed 4 sets of motor mounts, and i have never once been able to get the top one to just slide right in w/o causing damage to insert. I just brace the engine with a jack on a LEVEL surface and just disassemble the upper mount. I feel the lower one is a piece of cake, just maneuvering the bolts around the wheel well shroud is the fun part. But if you can get them to slide right it, more power to you. I just feel a little reasured that they are properly seated when i take everything apart.
Old 05-14-2006, 11:18 PM
Re: motor mounts
thanks guys since i have the 5 spd ill probably get them then. thanks
