Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-10-2006, 11:45 PM
2Geclipse95 2Geclipse95 is offline
clutch problem??
Hi i have a 95 eclipse GST and im having clutch/ transmission problems.. my clutch use to have a low point and now it got softer than before and the point is higher.. i grind going into 1st gear or reverse like almost 3 times a week but today i grinded atleast 7 times.. other times when i try to shift to first it feels like i hit a wall or something and it wont go in even though i have the clutch down all the way .. i could easily pop 4th gear into nuetral.. why is that?? do i just need a new clutch? or do i need transmission repaired as well??
Old 05-11-2006, 09:39 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: clutch problem??
Sounds like a clutch problem, do you plan on modding your car? Put your car and whatever mods you have in your signature so for future reference it's easier to determine. The clutches on DSM's are somewhat of a p.i.t.a, i believe chilton time pays 9 hours to do the job, definately two days and a couple cases of beer worth so be ready to get some work in. If you plan on modding your car further i would get a ACT or whatever your brand preference may be, something that's gonna catch well.
Also while you have the transmission out i would go ahead and change the fluid in it. I always used GM Synchromesh fluid, definately a noticeable difference with shifts.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-11-2006, 10:57 AM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
DUUUDDDEE I had that same Fu***** problem with my 95 GSX. It would be like a wall trying to put it into a gear...I'de have to jam it with all my might. The problem was the clutch fork...it got messed up so when you try to change gears...not everything was in alignment..which is why it was grinding. The problem lasted for so long since I had no money that it wore out parts of my ACT 2600 sideways pretty badly, so I just got an Exedy organic stage 2 and got a new clutch fork put on, and now it shifts like damn heaven.
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 05-11-2006, 08:18 PM
Thanks for the info and help guys.
