Old 05-10-2006, 09:28 PM
cpolaris502's Avatar
cpolaris502 cpolaris502 is offline
Code 6: Coolant Temp. Is it bad?
I have had me CEL go on a few times in the last month. The only time it goes on is when i am driving for a while at normal engine temp and i will shut the car off for a few minutes, like 10-15, and when i come back out and start up the car the light is on until i shut the car off again. is this a bad thing?
Old 05-11-2006, 10:17 PM
Re: Code 6: Coolant Temp. Is it bad?
bump
Old 05-11-2006, 10:26 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Hey man you should try resetting your ECU if you say your temp guage is normal. To do this just unplug the negative battery terminal for about 10 mins then fire it up again. Let your car idle for about 20 mins WITHOUT touching the throttle and letting your ECU adjust air and fuel ratios. After about 20 mins turn the car off again to save the data then start it up and take it for a spin. Hopefully your CEL will have cleared. Hope this helps
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 05-11-2006, 10:34 PM
skotman's Avatar
skotman skotman is offline
i actually had no idea that the ecu reprogrammed its air/fuel ratios after being reset, nor did i know that you had to turn it off after a few mins to save the data.
i thought "resetting" just referred to clearing the codes.
i've learned today.
Old 05-11-2006, 10:43 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
OR, you could pull the hazard fuse for about 10 secs...the ecu doesnt really save any settings, that would be pointless, it is constantly changing the variables to meet parameters set in the program, and if you step outside them it lets you know, running the car for 20 minutes will likely cause it to run real rich untill you clear it out some. those codes will stick around...the hazard fuse is the one at the very bottom of the under-hood fuse box when viewed from the passenger fender...it is a 10 amp.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-11-2006, 11:01 PM
Yeah whenever i pull the either the battery OR pull the Hazard fuse in the main shock tower fuse box, I notice after first startup that the engine undergoes a lot of idle fluctuations as the ECU is being programmed...and no this is NOT the car just idling high because its cold. The car is actually making adjustments based on any new alterations of the motor. For example, when i changed my O2 sensor, I reset the ECU and not only did it erase the CEL but my car felt alot smoother after the ECU was programmed. Resetting the ECU is something i occasionally do since our OBD0 ECUs dont do it automatically. I know OBD2 ECUs reset every 5 cold starts or so.
Old 05-12-2006, 07:55 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Actually, you should probably go ahead and pull the 15a ECU fuse as well as the hazard fuse. One time when my speedo cable popped out a bit, I threw a code 17 and I pulled the hazard fuse and it didn't reset the ecu until I pulled the ecu fuse.
Also, you don't have to let the car sit for 20 min. You should just reset the ecu and then start the car and let idle for 5 min. then cut it off, then start it up and drive as normal. Honestly, I don't think that's even necessary...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-12-2006, 11:47 AM
FrodoGT's Avatar
Its not, and of course the car is going to do some wierd crap to begin with, its going from absolutely no information, basically a new ecu. Its not saving anything but rather picking up where it left off the next time it starts.
Current project:
Rio Red 91 hatch.
Old 05-12-2006, 02:37 PM
ill reset the ecu, but there is nothing big that i should worry about with the code 6?
Old 05-12-2006, 02:54 PM
First, make sure your coolant temp sensor (underneath the distributor) is not sticking out, loose or broken.
2010 Honda CR-V EX
Old 05-12-2006, 03:17 PM
FrodoGT's Avatar
Yeah, they pull off very easily.
Current project:
Rio Red 91 hatch.
Old 05-12-2006, 09:25 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
It's a pretty important sensor, it is one of the main things that controls your air/fuel ratios. Also, if your car is equipped with vtec, it won't work while you have this CEL.
BTW, its the two wire plug on the passenger side of the head, it's a green and red wire plug.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-13-2006, 03:44 PM
i just checked that plug under the distributor, but i could not ell what color it is because it is coverd with 242,000 miles of dirt, but it was not loose. Oh well, it doesnt happen all the time and it doesnt seem to be a very big problem. Thanks for the help.
