Old 05-10-2006, 07:45 PM
unclebraddah unclebraddah is offline
S10 94 Blazer battery drain??
Ive got a 94 s10 Blazer. The battery started dying a couple weeks ago. its fine when running with the voltmeter over 14. I checked connections at the battery. Replced the terminal bolts. The belt is perfect. Replaced the wire from the alt. to the battery. Got a new battery. Checked the alt. at Napa. I was under the impression it would not start if the fusible link was bad. I will try to locate a short. Then I will replace the starter which looks very unaccessible. Do you think I am on the right track?
Old 05-11-2006, 12:37 AM
OverBoardProject OverBoardProject is offline
Banned
Re: S10 94 Blazer battery drain??
Have you installed anything new recently? If so that's probably where your problem is.
Next look at any aftermarket stereo's, amps, alarms, ect.
Next comes the starter.
Old 05-11-2006, 07:22 AM
Paperboy1996 Paperboy1996 is offline
Overboard is probably right check any new electrical items first.
I have seen an alternator work and still be bad - I pulled my alternator had it tested everyone said it was ok butt my new battery kept going dead, I finally broke down took it to a shop they said it was my alternator, they said it had a ground short in it that when the car was running it would operate normal but when I turn the key off it would slowly drain the battery, I didnt have anything to loose so I replaced the alternator and sure enough it corecter the problem.
Good luck
Old 05-11-2006, 09:44 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
take the negitive (-) off the battery with the key off you should have 50 milliamps or less on the dvom
