Old 05-10-2006, 04:50 PM
jessep28's Avatar
jessep28 jessep28 is offline
Couple Dumb Questions
00' Grand Prix GT- 54k
1) I am noticing small cracks in my serpentine belt (GM pointed it out too). Is it the best route to go Delco? If not, what is the best aftermarket belt I should get? Proper size?
2) I had it into GM for an oil change and they recommended power steering flush. At that mil age, is it necessary? I believe owners manual stated 45k, so I say yes.
Of course they were kind enough to quote me $200 all together for both belt and flush. I know belt cost and labor are out of line, but PS flush? I unfortunately don't have the knowhow or tools to do either repair. Sucks for me
Thanks again.
00' Pontiac Grand Prix GT
83,500 mi
Old 05-10-2006, 05:30 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Couple Dumb Questions
The serpentine belt probably needs changed as if there are cracks it may fail on you. The Goodyear Gatorback belt is one of the better belts for the application but most of the aftermarket manufacturers make good belts too. The standard size will work just fine just tell the clerk at the autoparts store what the application is. The GM belt is acceptable but it is expensive. As for the power steering flush it will increase the life of the rack but that decision is up to you. I have had some very high mileage cars and never flushed on yet. So as they say "you make the call." IMO get the belt changed and leave the power steering alone just top off the fluid!
Old 05-10-2006, 05:55 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree with Lynn. You can't go wrong with a GoodYear Gatorback Poly V belt. PN: 4060915. My second chocie is Gates.
Same here. I have never had a power steering flush done on any of my cars.
Timeslip 08/12/06
AF Community Guidelines
Old 05-11-2006, 05:59 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I'll third what Lynn and Bob said. Goodyear is an excellent belt, and if your original is starting to crack, it will only get worse. The power steering flush is not necessary, unless a system component failed and got metal in the fluid. If your car had over 150k and fluid looked really nasty, you could use an old turkey baster (make sure you don't borrow the wife's good one) to siphon out the old fluid and replace what is in the reservoir. Since the P/S pump is in such a lovely spot on our cars, I'd leave it alone, especially at 54k.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-11-2006, 09:36 AM
wlkjr's Avatar
wlkjr wlkjr is offline
I've never done anything to my power steering but add a little fluid and only one belt in 9 years and that was for maintenance.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 05-11-2006, 09:38 AM
BNaylor's Avatar
Originally Posted by wlkjr
I've never done anything to my power steering but add a little fluid and only one belt in 9 years and that was for maintainence.
And your current mileage on the odometer is _________?
I can never get over that. Simply amazing!
Timeslip 08/12/06
Old 05-11-2006, 09:39 AM
wlkjr's Avatar
306,000 miles
I edited my sig to reflect that.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-11-2006, 09:42 AM
BNaylor's Avatar
306,000 miles
Its what they call a milestone.
Timeslip 08/12/06
Old 05-11-2006, 09:43 AM
wlkjr's Avatar
I must have gotten the good one out of the batch. I can't relate to all the problems that some have with theirs. I do have a few small things occasionally but nothing major or that has left me stranded. I would love to have another one just like it.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-11-2006, 09:50 AM
BNaylor's Avatar
Our GPs are about the same age but I have under 92K miles.
When I checked the NADA suggested average retail my eyeballs nearly popped out for the mileage credit for resale value.
Timeslip 08/12/06
Old 05-11-2006, 09:52 AM
jessep28's Avatar
Would a serpentine belt going bad cause abnormal engine vibration on fan operation? It's the same abnormal vibration on all fan settings, AC/NO AC etc.
Just noticed that this morning. Thanks loyal Grand Prix...
83,500 mi
Old 05-11-2006, 09:57 AM
wlkjr's Avatar
Mine is probably worth about 35 cents wholesale. I have mainly been the only driver and have kept it clean. It looks almost new inside and the body has no dents or big scratches. I do have a windshield that has been cracked for over seven years but it's low and not in my vision so I have chosen not to have it removed. I'm afraid it might start leaking as I had the rear glass on my Grand Am replaced and it leaked until I had to pay out of my pocket to have it resealed. I did have to have both headlight assemblies replaced and that's the only external problems. I love driving this car and I'm going to keep it until it gives up the ghost. I'm even considering having a new motor put in when it expires.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-11-2006, 10:01 AM
wlkjr's Avatar
I don't think so. More likely to have a bad idler pulley. That's the one that puts tension on the belt. They do wear out the bearings and create a ridge around the circumference. But yours sound more like a bad blower motor.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-11-2006, 10:08 AM
wlkjr's Avatar
You have to watch out for dealers when you have them serviced. I have never had mine in for any kind of service that they did start making all kinds of suggestions of things I needed to have done. Even had them charge me for an oil filter and change on a Monte Carlo once when I was having warranty work done for a carburetor problem. They did remove that charge but wouldn't have if I hadn't raised a ruckus.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-11-2006, 10:15 AM
richtazz's Avatar
I agree with wlkjr, a heater fan vibration sounds like a blower motor issue. It's possible there is just some debris in the fan, causing it to be unbalanced. It's a fairly common problem on our cars. When you clean/replace the motor, install a cabin air filter from a same year Regal. GP's didn't come with them, but the slot is there for it. It will help keep moisture, dust and debris out of your motor, prolonging it's life.
