Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-10-2006, 04:36 PM
steviek's Avatar
steviek steviek is offline
head differences
Im curretly doing an engine rebuild and I swapped out my old damaged head for a different dsm head (don't know if its 1st or 2nd gen) anyways everything was goin fine until it was time to put the injectors back in. Since i sent away my old head I can't compare them but my injectors don't seem to fit well back into the head. I'm thinking there were some rubber fittings which the injectors went into that I must have forgotten to take out before I sent it away and this head just doesn't have them in place. I was just wondering if anyone knew what my problem is... and how to fix it. I'm pretty sure the injector inlet size is the same on the the two generations but I can't tell and I don't even know what head I have. Its the one with mitsubishi and 2000 on it if that helps. \
Thanks help is greatly appreciated
Maybe a picture?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-10-2006, 05:34 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: head differences
There are rubber rings that go into the head for the injectors. Most likely yours are still in the head you sent out. I put a 1g head on my car and its all the same as far as that goes. If you have a 1g head now you will not beable to bolt your 2g cam sensor to the head unless you drill and tap holes for it. Also the intake ports are way bigger compared to a 2g head. Just look at your intake manifold and compare it to the head ports.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-10-2006, 05:35 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
The injectors have both upper and lower seals the lowers are bigger than most o-rings, they probably just stayed in the head. They're kind of pricey about $20 for the whole set.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-10-2006, 05:38 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
you can get the lower seals from slowboy for $10 and the upper seals at a parts store for ~$5, all you have to do is get some o-rings that are approved for use with gas(make sure they are because the ones that arent will fall apart)
EDIT: There is a noticable difference in the runner size on the 1g and 2g head. IIRC if its ~1" its a 2g and if its any bigger its a 1g, Talon69 had the best idea, just compair it to you IM.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-10-2006, 05:40 PM
Talon69's Avatar
Here is a link for them. $10 for the set
http://www.slowboyracing.com/more.php?id=2069&
Current Cars
Old 05-10-2006, 05:49 PM
ez1286's Avatar
Fucking napa was $5.75 per injector for both seals.
Old 05-10-2006, 06:54 PM
blk_srt's Avatar
thats why you just get a gas o-ring set for ~$10 and it has a bunch of different sizes.
Mods:
Old 05-10-2006, 08:28 PM
steviek's Avatar
Yea Im missing the lower o rings how annoying is that.
I'm gonna try the gas o ring set anyone know what size they actually are.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-10-2006, 08:37 PM
blk_srt's Avatar
just take the injectors with you and have them size it
Mods:
Old 05-11-2006, 10:40 AM
steviek's Avatar
I got them from mitsubishi at 2.13$ a seal
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
