Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-10-2006, 03:41 PM
capriceforever's Avatar
capriceforever capriceforever is offline
repairing a motor mount
I've got a 1990 Caprice Wagon with an Olds 307 engine. The engine is flopping around like a fish out of water, the driver's side lifts up when you put load on it.
I've tried to get a look at the mount, but its near impossible from above or below, to get a good look at it.
Bottom line, not knowing whether its loose or broken, is this something that can be repaired without pulling the engine? That may decide the fate of this car!
Thanks
Old 05-10-2006, 08:01 PM
Blue Bowtie's Avatar
Registered Offender
Re: repairing a motor mount
You may not have to pull it, but you will at least have to lift it, then hold it safely while you work under the mount.
Old 05-11-2006, 11:15 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
This is a job that is best done on a lift. I've done them with the car on ramps with a bottle jack to raise the engine off the mounts. You should pull the other through (long) bolt out of the other side to make it easier. The broken one will fall apart when you raise the engine up.
On the new mount, take a few minutes to clean out the bolt holes that may have molded rubber in them. Otherwise it is hard to get the bolts started.
Bob
Old 05-11-2006, 02:46 PM
kahjdh's Avatar
kahjdh kahjdh is offline
i dont know about autos but i replaced a mount od a silverado and we put it in gear, reved and hit the ebrake, engine stalled and it was tilted. Bingo replaced the mount. But i dont know if you can do this with an automatic. Otherwise just get a board, jack the engine up a bit and wedge it to the side.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
