Old 05-10-2006, 12:09 PM
nickmont1627 nickmont1627 is offline
dumb question
i need to rotate my tires but im not sure if they need to be re balanced since they are being moved to different positions?
Old 05-10-2006, 12:27 PM
jessep28's Avatar
jessep28 jessep28 is offline
Re: dumb question
It's always a good idea to check the tire balance peridoically...especially if it hasn't been done before.
You will know if your tires are out of balance. Your iwll get abnormal vibration in the steering wheel - typically from when you don't feel the back tires out of balance and they are moved to the front.
00' Pontiac Grand Prix GT
83,500 mi
Old 05-10-2006, 07:49 PM
GregA's Avatar
GregA GregA is offline
Re: dumb question
My son is in an "Auto-Tech" school and they have rotated quite a few tires as "busy work."
They ALWAYS balance them again as part of the procedure.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 05-10-2006, 08:53 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: dumb question
rebalancing the tires is usualy not nessary on modern tires, but look at the tire tread. if you have uneven wear, especialy when comparing the inside tread wear to the outside, you might want to get them rebalanced since lose of rubber on one portion of the tire can cause an inbalance.
if you really want to get anal about it find a speed shop that will balance them on the car. that's the only true way to get them balanced for their position on the car.
Old 05-11-2006, 05:53 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: dumb question
I would only re-balance them if one of two conditions exist.
1. you can feel a wobble or vibration that increases with speed
2. the tires have a lot of miles on them since they were last balanced.
Keep in mind that many tire tech's are the low man on the totem pole at most shops, so the chances of them screwing it up and causing a vibration are high. Other than routine maintenance, I'm a firm believer in the old rule "if it ain't broke, don't fix it!"
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
