Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-09-2006, 11:55 PM
dsm_dude12 dsm_dude12 is offline
Consequences of breaking abalance shaft belt???
K so yetserday i was drivin my car to work. i took it to about 5500rpm's in second gear then let off as i hit the brakes and clutch for the next red light. as soon as i hit the clutch thoe.. the car started spuddering for about 2 seconds then died... so i got out and pushed it to the side of the road. poped the hood for a quick inspection and saw a piece of belt laying on the valve cover. since ive seen all the belts on my car except for the balance shaft one i assumed it was that. So i called the tow truck brought her home, started taring her apart. im at the point of getting the crank pulley off but it looks like the balance shaft belt is wrapped around the inside of the pulley... it just wont budge after u take the 4 bolts out. is there a puller i need or should i try prying it off? but anyways.. im just wondering... is there any damage to the engine since i broke the b/s belt or... is it just line the marks up and slap a new belt on and im good? thanks for any help guys!!
1990 plymouth laser rs turbo, pace setter header, k&n intake. turbo smart boost controller, greddy BOV, b/s removed, moderate head work. completly rebuild motor. Holly 255lph fuel pump. Auto-Meter a/f ratio and boost guage.
Old 05-10-2006, 01:53 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Consequences of breaking abalance shaft belt???
depends. Often, they will misalign the timing belt and you'll skip timing and ruin some valves. Take a look at your timing to make sure it's perfect before you just replace the BS belt and go. You might want to look into a BS belt removal kit too.
now - 2000 civic
soon - 2002 is300
Old 05-10-2006, 02:15 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I would just go without the belt, alot less hassle in the long run. Just make sure you get the one with the oil grooves or you run a risk of killing the oil pump.
95 Talon TSI AWD
97 Eclipse GST
Old 05-10-2006, 02:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
I would turn this into a full tbelt job, with or without BS removal. It's a pain in the ass to do BS removal with the motor inthe car. The front is easy, just leave the belt off, but you can't do that unless you rmove the rear shaft, which is where all the trouble is.
The other thing to consider is why did the front bs belt get thrown. More often than not, its because the front bshaft seized up. It spins somewhere around 15k rpm or higher even. If that's porked, you have no real choice but to do BS removal.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-10-2006, 06:50 AM
"porked"
lol, must be a northern thing?
now - 2000 civic
soon - 2002 is300
Old 05-10-2006, 10:40 AM
AF - Advisor
LMAO, it just might be.
Kevin Jewer
Old 05-10-2006, 03:41 PM
so basically.. what the plan is. drop the motor out? check to see if the timming is still correct on the timming belt. pull out the balance shafts with this removal kit. put the motor back in and i should be good??? I also am planning to change the timming belt while doing this because the old one looks pretty haggered.
Is it worth dropping the motor for to get the balance shafts out, or would it be easier to just struggle to get um out with the motor in the car? Also. where do i buy the b/s removal kit with the oil groov's from. any local parts store?
Old 05-10-2006, 05:33 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
you dont need to pull the motor but it would be easier to work on
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-10-2006, 07:12 PM
ok. well.. sounds like all the problems are solved! but one, how in the bluw hell do i get that fukin crank pulley off!!!!????
Old 05-10-2006, 07:27 PM
blk_srt's Avatar
4 bolts and it should slide right off
Mods:
Old 05-10-2006, 07:33 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Just wondering how the hell you think its your BS belt sitting on the valve cover? You not running top timing cover for cam gears? Not to metion it would have to clear the water pump and all the other shit, unless some freak thing the timing belt brought it up. But not likely i do not think.
Look at what im talking about here.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-10-2006, 07:44 PM
no, i got the timming belt cover fully on. but u can see the belt popping out like 5 inchs and torn behind the crank pulley.so id assume it blewout by the crank somehow then rod up through the alternator belt. and just by real realy luck. the chunk on top the valve cover had a part number on it.
Old 05-10-2006, 07:53 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
The crank sproket comes off by that huge bolt in the center and you need a slide hammer to get it off after the bolt is out.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-10-2006, 09:27 PM
k so i got the pulley off, took the t-belt cover off.. and yah there was no belt on the b/s sprocket. the balance shaft gear turned freely so im pretty sure the shaft's not siezed. unfortunetly when i lined the 2 timming marks on the cam gears up. the crank looked about 45 degrees off from the t-mark on the t-belt cover... thats how i check to see if its in time right? im also pretty sure when i turned the motor by hand i heard a valve hit a piston.. im guessing its time to rebuild the head?? this is the first time with all this timming shit for me.. so correct me if im wrong on anything.
Old 05-10-2006, 09:33 PM
blk_srt's Avatar
The timing mark on the balancer match up pretty good to the make on the cover. If a valve hit you could feel it when you turn it over like there would be resistance you could feel
Mods:
