Old 07-22-2002, 09:20 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
engine wiring
i wanna buy a engine harness for my car when i get my b18a but i want my harness wired so i can use a b16a. this might be confusing
i need to know if i buy one of those conversion things, dx to b16a, will all the connectors fit on my b18a
which leads to my other question are the b16a and the b18a wire connectors the same throughout the engine. so like if i buy that dx to b16a wiring harness, will my b18a hook right up to it ?
also do you know if it does work, could i use my b18a ecu on the b16a engine wirness.
any info would be helpful
plz tell me if i am not making any sense
Old 07-23-2002, 01:37 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yes its similar , but the only difference is that the b16 has 4 more wires for the v-tec and such.
Old 07-24-2002, 12:18 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
ok...DX to SiR wiring conversion will work for both vtec and non vtec B series motors running non obd, with extra plugs for Vtec solenoid and couple more for knock sensor etc...Mellowboy is right. Your PR4 ecu for LS will work but will need to replace it with a PR3 or PWO if you decide to run Vtec (ls-vtec). You will need to replace your distributor to a 1st gen vtec too...unless you're putting in a whole engine.:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 07-24-2002, 06:28 PM
first thanks to mellowboy and ef_lsvtec for the help.
do you mean that i need to put a b16 distributor on my ls so it will work on the harness ?
again thanks for the help
Old 07-24-2002, 11:23 PM
EF_LSVtec's Avatar
If you will do an ls/vtec then you need to use your b16 distributor (first gen)...91 LS distributor and plugs for the LS. Good enough?
AF Bay Area Crew
Retired SOLD 1/08
Old 07-25-2002, 02:09 PM
yeah thanks ef_lsvtec
transmission wiring help please danielgast46 F Series 0 02-28-2009 10:33 AM
vtec engine wire harness 94hondaacc Accord/TSX/Accord Hybrid 0 07-02-2003 02:59 PM
91 civic si engine wiring harness needed 91civhatch '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-05-2003 12:39 PM
I need an s15 engine wiring diagram dima1616 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 01-17-2003 10:30 PM
Engine wiring flipg20 Engine 3 11-04-2001 03:49 AM
