Old 05-09-2006, 09:37 PM
n9rkd n9rkd is offline
anybody had cracked block or head gasket
I got a 1995 4.3L.135k. My radiator fluid is getting low. I notice that there is an unusual amount of white smoke in the exhaust. So the question I have is... Has anyboby had a cracked block on their blazers? Or have most of you had to replace the head gasket? I have put in a ton of money on this and am dreading doing more work on getting the head machined or finding out there is something else wrong. I would consider replacing the head gasket if I were sure that was the only thing!
Old 05-09-2006, 11:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: anybody had cracked block or head gasket
white smoke on startup is just condensation.
I would top up your rad and your overflow tank and install a new NON-ACDELCO rad cap.
Stant is a good brand.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-10-2006, 12:42 AM
OverBoardProject OverBoardProject is offline
Banned
Listen to BLT, but still keep an eye on the coolant level for a while.
I've never seen a cracked block, but it's possible. Usually only happens when there's water in there that freezes.
If you have a bad head gasket your rad will probably over pressurize instantly when you start your truck in the morning. (the top rad hose will probably be rock hard instantly)
Old 05-10-2006, 05:07 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
the 96 and newer heads are thin pieces of junk, but seince you have a 95 your good there, a puff at startup is ok as blazer lt stated... but a continuous cloud is bad, could be cracked head, bad gasket, etcetera
Old 05-10-2006, 08:49 PM
BlazerLT's Avatar
AF -Advisor
Could also be condensation from an overly rich mixture that is just not rich enough to blow black smoke.
Sign of a leaking CPI injector or nut kit.
Old 05-10-2006, 09:07 PM
very true being a 95
Old 05-11-2006, 08:39 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I wouldn't go so far as a cracked block, although it is awlays possible, but highly unlikely. As for loosing coolant and white smoke in the exhaust, its enough to inspect it. Do you have any visable leaks of coolant? If not, I would defiently get the coolant system pressure tested. You won't necessarily see a pressurized coolant system if you head gasket is leaking, and it may not be the head gasket but the intake gaskets leaking. Either way, it a good idea to ge tthe system pressure tested and go from there.
Old 05-12-2006, 09:50 AM
534BC 534BC is offline
Also do a combustion gas test on the coolant system. Do it hot and cold. It will tell a difference than a coolant system pressure test.
