Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '88 - '92
Old 05-09-2006, 06:22 PM
scotty#457 scotty#457 is offline
91 gl 16 valve does not turn over
Battery good just had starter rebuilt will turn over and start when i jump the two terminals.
Old 05-10-2006, 09:55 PM
spasticone spasticone is offline
Re: 91 gl 16 valve does not turn over
When you jump the starter to the battery? That's a battery cable problem. Pretty common on all older cars.
I'd check them before you go to things like the ignition switch.
Old 05-10-2006, 10:48 PM
i found the problem,previous owner had installed a toggle switch in wiring beside the fuse panel behind dash i flipped the switch and it fired right up. thanks anyway's.
