Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-09-2006, 05:09 PM
copcarcrzy copcarcrzy is offline
water pump replacement
Is replacing the waterpump on a 96 LT1 hard. or fairly easy. electric fans
Old 05-09-2006, 07:31 PM
TommySS TommySS is offline
Re: water pump replacement
Would be straightforward operation.
Old 05-09-2006, 08:04 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
easy
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-09-2006, 08:42 PM
Blue Bowtie's Avatar
Registered Offender
Just be careful of the seal in the timing cover when you install the pump. I'd suggest a new cover seal, and use a protective sleeve to start the pump coupling into the seal.
