Old 05-09-2006, 05:06 PM
Egoman04 Egoman04 is offline
Send a message via AIM to Egoman04
Brake Question
Ok so my front driver's side brake is squeaking. It squeaks when i am driving, especially when i turn right, but the second i apply any pressure the squeak disappears. Its the same noise as if the pads need replacing, but when i looked at them, there is plenty of surface left. Also, it is not a warped rotor cause that was my next guess. Its a 2000 v-6. Any suggestions? I hate having a nice car that wont stop squeaking
Old 05-10-2006, 06:56 AM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Re: Brake Question
Have you taken the tire / caliper off and cleaned the rotor and pads with brake cleaner , then blow dry with air..........At the same time check your wheel bearing...any movement is bad...if it is the same as my 95...it is a sealed unit !!!
If you have a book ( Chilton or equiv.) ...see what it say about brake pad installation and make sure it matches....
Old 05-10-2006, 11:29 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Brake Question
Did you make sure you didn't "misplace" one of the locator clips?
Old 05-16-2006, 08:13 PM
Re: Brake Question
I cleaned the pads and rotors like u suggested.... still same thing. I had the brakes done by a local shop a couple of months ago cause quite frankly i didnt want to have to deal with it so im assuming that the locator clips r in the right place. this might be a dumb question but is it possible there is air in the master cylinder or the lines? would that cause a squeak cause of pressure?
Old 05-17-2006, 09:20 AM
wrightz28's Avatar
Re: Brake Question
No, air will not cause a squeak. Make sure they didn't bend the wear indicator onto the rotor. Aside from that they might have jsut used a way inferior pad company with crappy compounds.
Old 05-17-2006, 11:37 AM
Re: Brake Question
i just noticed a shiny stripe on the rotor... perhaps they did bend the wear indicator. guess i have to take off the tire and look again. oh fun
