Old 05-09-2006, 03:46 PM
FLastro FLastro is offline
99 Astro more fuel type problems
I have read all the fuel issues with the astro and still have not found a proven solution to this problem, any ideas?.
Started running rough then escalated to barely running only in idle. Changed the fuel filter and ran great for 4-5 hours next day went back to sputtering and stalling untill finally will only run on idle. 2nd filter (Pep Boys 7- $8). changed ran great entire day, next day back to them same old thing with one difference the cat was glowing cherry red at the intake side. I removed all the cat guts no more cherry red but still does not go beyond idle.
Does anyone have an answer?
Old 05-09-2006, 08:39 PM
Blue Bowtie's Avatar
Registered Offender
Re: 99 Astro more fuel type problems
Connect a fuel pressure gauge to the test port near the rear of the engine (dog house needs to be removed).
Old 05-12-2006, 10:15 AM
drew300 drew300 is offline
I'd suggest cutting the old filter and seeing if they're plugged by "something" from the fuel tank. After all, it ran with a new filter twice.
As for pressure, my '97, (is a '99 the same?) they need more pressure to start than run, and a GM service rep told me "minimum 60 psi" to run. I had 59 psi on the guage I borrowed. I had starting problems, but it ran fine after starting. With a new fuel pump, but no pressure reading, (I returned the guage), it starts and runs fine.
