Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-09-2006, 02:09 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
DSMlink
Is the DSM link supposed to hook up direct to a computer....any other attachments needed? I cant get mine to work...
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 05-09-2006, 02:17 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: DSMlink
well, assuming your have a socketed 95 Eprom ecu, with the Dsmlink chipset installed you just unhook your old ECU and replace it with the 95 ECU. From their It depends on what cables your using to go Online with to the ECU. Are your running a dirrect serial cable to your laptop or PDA device? Or are you running a Serial-to-Usb adaptor cable?
Their is a list of supporting USB adapter cables on the Dsmlink forum. I had a problem connecting my USB adaptor, I had to go into the Options, and change my COM PORT to COM4.
Old 05-09-2006, 08:53 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: DSMlink
Is your dsmlink cable db9? thats a dumb question to ask i guess lol since thats the way they come. I got a socket that goes from db9 to usb from walmart for $25. The older computers use db9 but not newer ones. Newer ones use USB for everything.
I have not used my dsmlink yet since my car is still apart when i purchased dsmlink 3 months ago,but it goes from odb2 adapter to db9 cable but had to get a adapter that went from db9 to usb like i said.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-09-2006, 10:07 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: DSMlink
I have a laptop without serial ports so i used a serial to usb, if you use one you have to install the software for it. Thaen go to control panel ->sytem ->hardware (tab) ->defice manager. Then go to ports (comm an lpt) click that and see what comm port the signal is coming from the go to dsmlink and click edit -> options ->config and make sure the correct com port is selected. Hope that helps.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-09-2006, 10:43 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: DSMlink
Newer laptops do still come with serial ports, if they are "business class" laptops. Engineers will always need serial ports to talk to automation systems. But they're usually a little nastier and cost more money.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
